Re: Farmall A lift?
Posted by georgeky on February 25, 2007 at 15:58:28 from (64.12.116.71):
In Reply to: Farmall A lift? posted by David in Ohio on February 25, 2007 at 15:01:22:
David It will be very difficult to raise a bush hog with manual lift. It is not cheap to rig hydraulics to your tractor. The engine block has no place to mount the pump. I have seen a couple rigged with power steering pumps from cars. You can buy a PTO driven pump they are expensive, and will not work any time the clutch is pushed in. If you had a super A or C engine block would be the best way as they are set up for live hydraulics and will fit right in your tractor, however you would still need a reservoir to hold oil. To me I would think it would be easier and cheaper to buy a tractor say super A or C or even a H already set up with hydraulics. Have you considered a pull type mower this would be the easy thing to do.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
