Re: Farmall A No Start!
Posted by plh_in on February 26, 2007 at 07:26:46 from (207.250.220.192):
In Reply to: Re: Farmall A No Start! posted by JayWalt on February 26, 2007 at 06:55:16:
It is negative ground. It currently is connected as follows: 1) +12v from battery to one post on solenoid 2) 2nd post on solenoid goes to the starter 3) 3rd small post on solenoid goes to the key switch I believe...
So, do I connect the Neg from the battery to the frame of the solenoid & 12v (pos) from the batter to the small post on the solenoid (small post as I mention above that goes to the switch)
Thanks...I just want to be sure & not blow any part that may be good!
Today's Featured Article - History of the Field Marshall Tractor - by Anthony West. Any restorer who has some knowledge of turn of the century farm machinery, will recognize the name Lanz Bulldog!! This machine was to say the least unusual in its appearance. The huge flywheel and coffee percolator shaped exhaust. Along with square body lines and cylinder head protruding forward of the front axle. Would become the visual differentiation that people would quote to separate the Lanz from other period machines. The Marshall company based at the Briannia Works in Gainsborough ... [Read Article]
