Re: Farmall A No Start!
Posted by Janicholson on February 26, 2007 at 09:31:21 from (199.17.6.122):
In Reply to: Re: Farmall A No Start! posted by plh_in on February 26, 2007 at 05:58:17:
The test is as follows. With the solenoid in hand, connect the body of the solenoid (mount tabs) to the negative battery terminal with a jumper wire, or battery jumper cable. Connect the side of the solenoid that was connected to the battery + to the battery + with a wire, or jumper cable. Do not connect the starter end of the solenoid to anything. Get an ohm meter setup so it can be used between the two big terminals of the solenoid. Use a thin wire to energize the solenoid by connecting the bat + to the small S terminal of the solenoid. This will cause it to click loudly. Now measure between the two big terminals, There should be no resistance. The ohm meter should read zero, or less than .1 ohms. If it reads tens of ohms, it is bad. You can also test the resistance (momentarily) while actually trying to start it. The resistance should also be very low. A starter draw gauge that is held against the heavy battery cables (cheap at the NAPA store) is a sure indicator of current to the starter. What did they do to the starter? If they replaced the drive gear, and bushings, and brushes, then it should be OK. If it is jambed (Possible) put the tractor in High gear with the key off, and rock it back and forth violently. If the fan twitches, The starter is not jambed. If it was jambed, there will be a deep clicking as it comes out of being jambed. Good luck, JimN
Home
| Forums
Today's Featured Article -
History of the Field Marshall Tractor - by Anthony West. Any restorer who has some knowledge of turn of the century farm machinery, will recognize the name Lanz Bulldog!! This machine was to say the least unusual in its appearance. The huge flywheel and coffee percolator shaped exhaust. Along with square body lines and cylinder head protruding forward of the front axle. Would become the visual differentiation that people would quote to separate the Lanz from other period machines. The Marshall company based at the Briannia Works in Gainsborough
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
