Re: Old H workout, and noises...?
Posted by Janicholson on February 26, 2007 at 09:45:15 from (199.17.6.122):
In Reply to: Old H workout, and noises...? posted by Matt Page on February 26, 2007 at 09:13:04:
TIming could be advanced too far causing spark knock. If the static timing is perfect, then I might look into the advance mechanism in the distributor (under the breaker plate. Another way to test it is to use a small (old lAWN MOWER) gas tank full of premium fuel, if that cures it, the timing is probably an issue. JimN
