Posted by redblood on March 19, 2009 at 13:54:39 from (205.188.116.19):
In Reply to: farmall c posted by d farms on March 19, 2009 at 12:36:12:
I just got done setting mine. When you push the governor output arm backwards it may fall into a loose spot. I pushed the carb wot (backwards) and the governer arm to the point that the slop was gone but not preloading the spring (zero) and it works very well. Also high rpm may be off. Adjustable with the screw on top. Screw it out to set rpm higher. You need to have a way of measuring rpm, Ie tach.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
