Low oil pressure A
Posted by dave guest on February 26, 2007 at 19:13:55 from (4.229.177.193):
In Reply to: Farmall A Replacement Block posted by abdsell on February 25, 2007 at 09:17:03:
This is like edge of red zone after hour or two in summer. No water pump. Rad supposed to be OK. Added electric fan in addition to belt fan and heavy oil, helped a little. I took it from sitting out for 10 years and got the engine free, replaced the valves, head and gasket. Had the pan off but forgot to look at pump. Thanks for all the tips and short cuts. I will pull the pan, check mains, and try some things on oil pump. Appreciate all the input.
