Re: Sleeve Puller/Installer
Posted by AC BOY on February 26, 2007 at 19:56:29 from (205.188.116.133):
In Reply to: Sleeve Puller/Installer posted by DelMN on February 26, 2007 at 04:46:09:
You don't need a puller , I just flipped my block up side down and put it in a press and pushed them out. I cleaned the block real good and took a block of wood and a rubber hammer and a couple of smacks and they were in. Use castor oil on the o-rings if you have the wet or dry sleeves. It will not make the o-rings swell. Almost all other oils will cause the o-rings to swell making it hard to install the sleeves.
