Re: Should not be possible
Posted by dave2 on February 26, 2007 at 20:57:43 from (139.139.35.70):
In Reply to: Re: Should not be possible posted by Doc Larry on February 26, 2007 at 19:38:23:
They fit a VW TDI motor. The Bosch number is:
GN 912 0100226188. You can probably cross reference to a common brand there.
http://www.mccormick-freunde.de/technik.htm
If you can open this link, go to the far right column (schrauber tips)and click the "gluhkerzen" link. This gives you a picture. The text just explains the use and says wire them direct.
