Farmall Tractors Discussion Board
Re: Gear Pattern on MD?
Posted by Aaron on April 23, 1999 at 19:54:34:
In Reply to: Gear Pattern on MD? posted by TMAC on April 23, 1999 at 13:51:09:
This is a BAD idea. If the engine is truely stuck, you can destroy nearly everything in it doing that. I have an old Allis Chalmers with a 201ci gas that was stuck. The previous owner had tried to do this very thing. When I took the enigne apart, I found 2 rods bent nearly in half. Those same 2 cylinders had liners that were broke into several pieces. This was a wet sleave engine. I believe the M is dry sleave, so this may destroy a bore. Bets bet is to pull the plugs or injectors and add a bunch of penetrationg oil. Evil things can happen in the entire driveline if thay engine is truely stuck.
Aaron
Post a Followup
: Re: Re: Gear Pattern on MD?
