Re: Farmall Cub transmission and rearend grease
Posted by Bigdog on February 27, 2007 at 14:06:04 from (65.185.32.9):
In Reply to: Farmall Cub transmission and rearend grease posted by rio1 on February 27, 2007 at 13:26:38:
The tranny / differential is drained from a plug on the bottom front edge of the tranny case. The final drives are drained by removing the pans from the bottom and dumping it out.
You can use either 80 - 90 wt. gear lube or Hy-Tran in the trans and final drives. There is a level plug for the tranny on the left side near the bottom. Fill til it runs out of the plug. On the finals fill to just below the seam where the pan meets the casting. I you keep the level below the gasket it reduces seepage.
