Re: 301 LP engine on gasoline
Posted by K.B.-826 on February 27, 2007 at 15:20:36 from (68.115.110.247):
In Reply to: 301 LP engine on gasoline posted by Dan Dargeloh on February 27, 2007 at 13:58:23:
The gas version has a hard enough time lasting on regular pump gasoline for anything other than light work. 93 octane is recommended when running hard. As long as you're in there, carefully measure the bores, hone or have them machined oversized if needed, and install new gas pistons, as well as wrist pins and bushings. Those engines are famous for developing a knock as the wrist pins wear, so I would definetly recommend starting with new parts. The LP head and manifolds should work fine. Make darn sure your valve guides, valves, and seats are good, as burned valves was the other major problem. Oil runs down the valve guides and forms deposits on the valve, which causes poor heat transfer from the valve to the seat. This is why LOW ASH oil is the only oil that should be used in these engines. Your Case-IH dealer will have it, as will any good farm oil supplier. Consider using new head bolts, make sure the head and block are flat, give the head gasket a light coat of hi-tack sealer, and retorque the head bolts after you have had the engine hot and under a good load for a couple hours. Once the engine is just cool enough that you can stand to work on it, crack each head bolt loose and retorque to 95 ft lbs. one at a time in sequence.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
