Re: How do I 'Test' my H?
Posted by GordoSD on March 01, 2007 at 13:52:21 from (66.115.200.140):
In Reply to: How do I 'Test' my H? posted by Mike CA on March 01, 2007 at 10:59:36:
Drop the pan before you replace the oil and filter. Clean all the sludge out of it. Drop the oil pick up unit and clean it also. Remeber where the 4 long bolts came out of the pan. Reinstall with new gasket. Check to see you have the copper washer on the pan drain plug. Wouldn't hurt to pull the valve cover and slosh some diesel fuel all around there, and then high pressure air clean. Or better if you have one the spray gun that has a large nozzle, can for cleaner, that hooks up to your compressor. While your spraying that ga ahead and hit the big chunks og grease anywhere else on the tractor. Makes them easier to get off whatever method you use later. Pull starting is an option if you want to hear it run before you tackle the starting system. Like others said, stay away from 8 volt, but go to elec supply house and get a 1/0 cable made up to go from battery to starter. Flat copper braided cable for ground is good. Perfectly clean connections, brush, sand polish! Check terminals at switch for clean also. If any wires get warm when you are cranking something is loose. What manuals do yuou own? We're not going to do ALL your research for you . Gordo
Gordo
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
