Re: How do I 'Test' my H?
Posted by CNKS on March 01, 2007 at 17:50:10 from (204.249.178.32):
In Reply to: How do I 'Test' my H? posted by Mike CA on March 01, 2007 at 10:59:36:
Forget pulling something, it is simply not necessary. Find an empty road, put it in 5th and run it a couple of miles. See how it handles hills. But, the best way to check the engine is to run a compression test -- that will tell you if you need rings, valves, etc. Compare your readings with those on www.weberstractorworks.com.
