Re: Replace H axle gasket
Posted by Craig T on March 01, 2007 at 19:32:02 from (204.11.176.189):
In Reply to: Replace H axle gasket posted by Reddy Eddy on March 01, 2007 at 18:23:12:
My method takes a lot of work and time. It took me a whole Christmas vacation to get mine done. I did what you described. Jack up the whole rear end and pull the PTO. Hold a big wrench on the bolt on the bull gear and spin the wheel. That should give you enough leverage to break it loose. Then use a cart or cherry picker to pull the wheel and the housing right off. Good luck.
