Re: How do I 'Test' my H?
Posted by Mike CA on March 02, 2007 at 08:25:56 from (214.1.211.251):
In Reply to: How do I 'Test' my H? posted by Mike CA on March 01, 2007 at 10:59:36:
To answer a few of the questions... Yes I have started it. It has a converted 12 volt system with a key. It would cut out after 5 minutes of running, and the Carb was suggested to be the problem. I have some instructions on how to clean that up. Also we found the solenoid wasn't grounding properly, so I have a new one waiting to go on.
The hills idea sounds like the best. I didn't realize a hill would put that much strain on it, so I'll give that a shot.
Gordo, when you said I should clean the sludge out of the pan... this sounds silly, but where does the sludge go? Do you just collect it in a container and take it to a recycle drop off? I ask because I can't hose off grease and oil in my front lawn. So I have to have a plan in place for proper cleaning and disposal.
