Re: SMTA Postivie Ground + and -'s
Posted by two-man on March 02, 2007 at 09:32:34 from (64.192.134.66):
In Reply to: SMTA Postivie Ground + and -'s posted by sflem849 on March 01, 2007 at 18:21:54:
Original OEM was positive ground on 6-volt. For the softer mind go to negative ground & change the wires on the ampmeter gauge & coil. Polarize the the voltage regulator and ease that overworked mind.
Jumping the battery is always +/+ & -/- regardless of which terminal is grounded.
Part of the reason the industry other then the alternator got away from positive ground.
