Re: SMTA Postivie Ground + and -'s
Posted by Bob M on March 02, 2007 at 11:38:53 from (151.190.254.108):
In Reply to: Re: SMTA Postivie Ground + and -'s posted by John T (Question Bob n Ji on March 02, 2007 at 10:46:18:
Geez John T - Now you're getting into the realm of theoretical physics, electrochemistry and other such esoterica. And that kinda stuff is way beyond the capacity of my (mechanical engineer's) brain to comprehend.
I do recall this however about acid battery action: Your not "storing" electrons (or electron holes) directly in opposite plates as a battery is charged and discharged. Rather you are converting and storing compounds (elemental lead and lead oxide) that contain unequal number of electrons. These difference in electron quantities are then balanced by the electron current flowing flowing from one plate to the other and out through the external circuit.
Or maybe not....I dunno....(!)
