Re: Farmall H Problems
Posted by Farmall Bob on March 08, 2009 at 18:43:34 from (24.31.158.92):
In Reply to: Re: Farmall H Problems posted by tgrewing on March 08, 2009 at 18:17:05:
Hi Tgrewing,
You may be talking to the wrong person when it comes to tractor electronics. I mostly follow the manual word for word to get me through this type of problem. 7 volts at the distributor? Doesn't it receive a big boost when it goes through the coil? Did you change the condenser at the same time you changed points? I check volts at the plug by letting it spark to ground as I turn the engine over. If it has a bright blue spark it should be OK. Hope this helps.
Bob
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
