back to my 2 questions on the H
Posted by banjo on March 02, 2007 at 21:10:27 from (65.67.203.101):
The other question is which farmall hood emblem, aluminum or tin? and my throtle has the squared notches, is that what you call the saw tooth? Actually it had the friction on it and i changed it to the notched one. I just like the looks of it better . It was a used one i aquired.
Now another question just came to mind.I changed my steering post as the one on it was a galvanized pipe. There is a square plate bolted under the belly pump rod hanger . It has 4 holes in in, is this an add one or did it come that way and what would of been in the 4 holes?
Also on the belly pump rod holder there are 2 holes close to the steering post. What was in them? Right now i have a toggle switch for an ignition switch in one and another toggle for the light switch in the other.
I know that was more than 2 qusetions but i had to make up for forgetting one in the other post.
