Re: Farmall A Information
Posted by gene bender on March 04, 2007 at 07:39:47 from (67.55.226.214):
In Reply to: Farmall A Information posted by Gary P. Davis on March 04, 2007 at 07:23:59:
You have a 1948 SA #s started with 250082 ended with 268195 6vpos gnd 1st SA in 47 STARTED WITH #250001 Yours should have a hy system with rockshafts. Pump is located below the mag with lines running to the rockshaft below the gastank. It is possible yours wouldnot have the hy system but a plate over the housing where the pump could mount.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
