Re: 140 Alternator (conv) wiring: What's wrong??
Posted by Sam#3 on March 04, 2007 at 21:06:26 from (12.214.113.142):
In Reply to: 140 Alternator (conv) wiring: What's wrong?? posted by Nawlens Gator on March 04, 2007 at 18:56:52:
I'm confused by your wiring and rewiring so let me start with a clean page. (I broke my slate fifty years ago.)
First start with the battery charge lead. Wire a lead from the alternator to the positive terminal of the ammeter. Continue from the negative of the meter to the battery terminal of your new switch. That is your battery distribution point. Run a lead from this terminal to the Positive terminal of the battery. This completes the charge lead from the alternator to the battery. Run a lead from the ignition terminal of the switch wire to the coil. This lead will supply battery to the ignition when the switch is turned ON. From the start terminal of the switch run a lead to the operate side of the starter solenoid (a small terminal not a large battery terminal.) This is will activate the starter when switch is turned to START.
The lights can be handled two ways. 1) As you have them now from the accessory terminal or 2) from the Battery terminal to the light switch. If wired to ACC term you can activate the lights without the Ignition being activated.
Hopefully this will help. I’ve attempted to do one function at a time. The charge circuit, The ignition circuit, the start circuit and the lights. Check each as you go then do the next.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
