Re: Water in steering gear?
Posted by City-Boy McCoy on March 06, 2007 at 02:54:23 from (68.221.167.135):
In Reply to: Water in steering gear? posted by Glen Wentzell on March 05, 2007 at 19:58:35:
I don't mean to hurt your feelings, but this all sounds as though it was easily avoidable. If your tractor had been serviced at regular intervals and fluids changed, it probably would not have happened. If you have owned your tractor for two years and don't yet have a manual, then you SURE ought to have someone servicing your tractor for you annually.
If something doesn't work right, don't force it. mike
