Re: Cub Crankshaft Pulley Tool
Posted by Haas on March 06, 2007 at 08:01:19 from (70.178.151.15):
In Reply to: Cub Crankshaft Pulley Tool posted by S/C Bob on March 06, 2007 at 04:36:32:
Can't send a pic right now, as I am not at home. However, the one El-toro made looks similar to one I made and used a couple months back. Mine was made from 5/8 plate. I did not use a hydraulic jack, but instead drilled a hole in the plate and used a 5/8 threaded rod and nut as the jack. Put a piece of steel over the crankshaft end so you don't mess up the threaded hole there. The pulley on my cub came off fairly easy. Just make sure you pull on the hub of the pulley, not the flange.
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
