Re: Farmall H Countershaft/brake drum seal
Posted by Randy in NE on March 07, 2007 at 13:05:13 from (204.124.193.192):
In Reply to: Farmall H Countershaft/brake drum seal posted by Rob Flory on March 07, 2007 at 09:06:13:
As the others have stated, the original seals are considerably thicker than the new ones. The problem with putting two seals in there is that the outer one will not get lubricated and will wear prematurely. Packing grease between them will extend the wear of the outer one. Unless there is a groove in the shaft, only one seal is necessary to do the job.
