Re: Grinding gears on my IH 1486 (Trans brake)
Posted by Hugh MacKay on March 07, 2007 at 16:26:13 from (209.226.247.123):
In Reply to: Re: Grinding gears on my IH 1486 (Trans brake) posted by Ron Bailey 1486 on March 07, 2007 at 07:31:34:
Ron: The 1486 operator's manual will tell you exactly how to adjust that transmission brake.
If your new to these large chassis IH tractors, you probably have a habit to break. When you stop forward or rear movement of tractor, NEVER push the clutch pedal all the way down until tractor stops moving. The clutch pedal activates that trans mission brake when down. You have to learn to press clutch pedal just far enough to release the clutch, then after tractor stops push it rest of way down. Applying that brake while tractor is moving will tear it to shreds in a month.
Don't ask me how I found out. I will tell you it was 30 years ago.
