int. 3414
Posted by d schrerms on March 07, 2007 at 16:37:54 from (69.48.14.32):
i am reposting this because i do not think that it went the first time. just got a int 3414 with a loader . ther are several levers that i am not sure what they are for. 1. there is a regular lever for the trans gears one through four plus reverse 2. high / low 3. a lever that seems to switch you from forward to reverse regaurdless of were the gear shift is. they all require the clutch to be depressed to make them work. any ideas? thanks Dave
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
