Re: Grinding gears on my IH 1486
Posted by Owen Aaland on March 07, 2007 at 17:00:14 from (65.165.246.14):
In Reply to: Grinding gears on my IH 1486 posted by Ron Bailey 1486 on March 07, 2007 at 07:18:01:
"the guy was supposed to replace sometype of gear break" If he replaced the tranmission brake with the original style then it is adjusted like the manual shows. If the brake assembly was replaced with an after market version then the adjustment procedure may be different. The adjustment is made on the right side of the clutch housing. There is a rod that is operated off the clutch shaft. On the rear/lower end is an adjustable clevis that is attached to a lever. The adjusment is made at this clevis. 1) Remove the pin through the clevis. 2)With the clutch held all the way down, push back on the lever, and adjust the clevis so the pin holes line up. 3) Turn the clevis 1 1/2 turns farther out, relea se clutch, and replace pin. Check adjustment by running the engine about 1000 RPM. Fully depress clutch. Wait about 3 seconds and you should be able to shift into gear without grinding. Extend clevis out further on rod if transmission does not stop soon enough. If the brake pad inside is worn out you will not be able to get the tranmission to stop correctly if adjusted like this. If the rod on the right side is welded to a tube with a gease zerk on it the adjustment is different. This system uses a metalic brake pad and a spring inside the tube in the rod. This style is adjusted with the clutch released. Simply adjust the clevis so the pin can be inserted.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
