Re: Grinding gears on my IH 1486
Posted by K.B.-826 on March 07, 2007 at 18:05:31 from (24.180.155.91):
In Reply to: Grinding gears on my IH 1486 posted by Ron Bailey 1486 on March 07, 2007 at 07:18:01:
Read Hugh MacKay's post below, and keep in mind that on these tractors, it is impossible to shift into high, low, or reverse without grinding unless the tractor is at a dead stop. If you are at a dead stop with the clutch pedal all of the way down, the engine at low idle, and have waited at least 3 seconds and you still have grinding, then your trans brake is out of adjustment or the pad is gone.
