Re: stupid questions about A/Super A motor
Posted by Nat 2 on March 07, 2007 at 23:06:20 from (64.80.110.50):
In Reply to: stupid questions about A/Super A motor posted by drab cat on March 07, 2007 at 20:45:32:
The original engine was designed for gravity fuel feed. I don't think it has provisions for a fuel pump. Are you sure the fuel tank is in the "stock" location?
It was probably positive ground, unless Yale was weird at the time. Most everyone was positive ground. Really doesn't matter. All that'll happen if you get it backwards is the generator won't charge until you polarize it, and then the Ammeter will read discharge when the generator is charging.
Find TDC on the compression stroke for cylinder #1. Use the thumb-over-plug-hole trick, feel for whooshing air, then line up the mark on the pulley with the timing pointer on the engine. Pull the distributor cap, turn distributor until rotor points at #1 tower on distributor cap when you replace it. That should be good enough to start.
