Re: international pto
Posted by georgeky on March 08, 2007 at 16:19:51 from (64.12.116.71):
In Reply to: international pto posted by tom nj on March 08, 2007 at 13:53:14:
Jim is right there are different shafts used. If you look at serial tag to see what letters are stamped on it you can tell which shaft it has. If your 300 had IPTO originally it will not take the H unit. If it had transmission driven it may work,but I am not sure there could be difference between rowcrop and utility. If your tag has a R on it the trans drive pto should work.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
