Re: Super A Touch-Control fluid
Posted by CNKS on March 09, 2007 at 17:53:53 from (204.249.178.32):
In Reply to: Super A Touch-Control fluid posted by Patrick B. on March 09, 2007 at 17:42:01:
Good idea to drain it and replace with Case-IH HyTran or an oil that meets HyTran specs. The original touch control used SAE 10W before touch control fluid appeared. HyTran replaced touch control fluid. It would probably help to get the water out if you drain, replace, run, drain and replace again -- will take twice as much oil, though.
