Re: tire size for Farmall H
Posted by Andrew Z on March 10, 2007 at 04:19:52 from (12.76.129.170):
In Reply to: Re: tire size for Farmall H posted by BOBLYN on March 10, 2007 at 02:55:05:
My 46 H comes in at 3950lbs and that is with no weights cast or liquid. it does still have the belly pump and belt pully, and PTO. Im not sure what class your looking to pull in but that the case in 4000 with the H. In 4500lbs my father runs a set of rear weeights and one set of fronts. that gets him to 4500lbs on that. Also his Super H is striped of the hydro. pump and belt pully. If you looking at just doing some fun pulls in 4500lbs then I would put on a set or two depends on the weight of operator and go have some fun. If you have a 4000lbs class I would pull that tho, cause a stock H will pull much better in that class. You will not have to compete against Oliver 88's Farmall M's, and stuff of that nature.
Andrew
