Re: Farmall C problem
Posted by ScottyHOMEy on March 19, 2009 at 16:23:17 from (70.105.234.113):
In Reply to: Farmall C problem posted by Alaskapete on March 19, 2009 at 16:18:25:
I'd have said coil but you've seen to that. Could also be the condenser.
If you've got spark, I'd look at restricted fuel. Check the strainer in your sediment bowl first, then the screen in the inlet elbow to the carb. If enough crud got past those, you may need to blow out the carb.
For that matter, how much gas is in it? You'll run out of fuel before the tank is wmpty.
