Farmall Tractors Discussion Board
Re: How to replace 4th sliding gear H
Posted by justin on April 25, 1999 at 14:03:04:
In Reply to: How to replace 4th sliding gear H posted by Adri van Dijk on April 25, 1999 at 11:58:41:
To replace the 4&5thslider, you need to have the deck and front bearing cage removed.. it will take more time to remove the front bearing cage than to remove the deck.. once both these parts are removed, all you need to do to remove the main shaft, is to take out all three bolts in the mainshaft bearing retainer, and pull the whole unit from the ring gear.. with the main shaft and gears out, remove all gears and inspect the main shaft for chatter marks. If chatter marks are evident in the 4&5th slider area, and are excessive, you will need to replace the mainshaft, 4&5th slider, and atleast the mainshaft pilot and front bearing cage bearings. If you need any of the transmission gears or a new mainshaft, just email me
Post a Followup
: Re: Re: How to replace 4th sliding gear H
