Farmall Tractors Discussion Board
Re: Farmall 656 Manual
Posted by Harold H on April 25, 1999 at 16:58:53:
In Reply to: Farmall 656 Manual posted by Mark Seymour on April 25, 1999 at 13:05:18:
Mark,
Niether the Farmall 656 or the Farmall C were built in the mid 50's. The Farmall 656 was built 1965 - 1972 in both gear drive and hydrostatic drive models. The Farmall C was built 1948 - 1951. The Farmall Super C was built 1951 - 1954. You will need to post serial numbers to get exact year. If serial number is missing you can get close using the casting date codes found on different castings.
Harold H
Post a Followup
: Re: Re: Farmall 656 Manual
