Re: 504 torque amp.
Posted by D Slater on March 11, 2007 at 19:34:37 from (152.163.100.199):
In Reply to: Re: 504 torque amp. posted by makin'hay on March 11, 2007 at 18:09:20:
One other thing,if the T/A clutch is not disengaging when you push clutch to shift gears you will get hang up or hard to take out of gear, more so if on a grade and tractor tries to roll a different dirrection than gear dirrection. Do you have this problem?
