Re: Grinding gears on my IH 1486
Posted by JayIH man on March 11, 2007 at 21:09:16 from (70.243.238.51):
In Reply to: Grinding gears on my IH 1486 posted by Ron Bailey 1486 on March 07, 2007 at 07:18:01:
To solve all grind problems on the 86 series you can update the trans brake to a 30 series which is electic over hyd. It has 2 piston brakes that are in speed trans bottom cover. Check with Case and see if this kit is still available. If not find a 30 series in salvage and rob the parts to correct this problem.
