Re: Motor mounts
Posted by RustyFarmall on March 12, 2007 at 07:02:21 from (66.43.253.11):
In Reply to: Motor mounts posted by Outback Dave in WA on March 12, 2007 at 01:22:45:
Quite often on a truck, you need to remove the entire front clip, with radiator, to get the engine out. Some of those trucks even required removing the cab first.
