Re: Weird IH carb found
Posted by Gary in Mozarks on March 12, 2007 at 09:06:31 from (66.43.47.76):
In Reply to: Re: Weird IH carb found posted by RustyFarmall on March 12, 2007 at 08:17:19:
I think you are right, I would guess its for a Stationary engine? I ran across a site on the internet that sold conversion kits to make Briggs & Stratton, kohler etc, engines dual fuel. They were simular. The cheaper kits just converted the gas carb to propane, but the better kit was designed so you could switch it back and forth. I think for generators.
