Re: Farmall C problem
Posted by El Toro on March 19, 2009 at 16:59:53 from (205.188.116.73):
In Reply to: Farmall C problem posted by Alaskapete on March 19, 2009 at 16:18:25:
Pull a plug wire off ASAP when it quits running and check for fire while someone makes an attempt to start the engine. Hold the plug wire about 1/4" away from the plug. If there's very weak or no fire replace the condenser since it's cheaper and if that doesn't help its probably the coil. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
