Re: 48 Cub with Issues....
Posted by K-Mo on March 12, 2007 at 16:28:18 from (65.169.189.2):
In Reply to: 48 Cub with Issues.... posted by Lane R on March 12, 2007 at 15:36:57:
Either a bad connection at the switch or a bad switch. I am assuming you have a good ground. To check the ground, check the for voltage between the gounded battery post and the starter case. If voltage is indicated when you pull the starter, you have a bad ground.
Check the voltage on the switch stud and pull the starter. If the voltage drops to zero, you have a bad connection. If the voltage does not drop, you have a bad switch or starter.
I had a similar problem. The battery connection was tight and looked clean. I connected and reconnected the cable several times thinking any bad connection would be resolved. I removed and cleaned the internal switch contacts. It wasn't until I cleaned the mating surfaces between the cable and switch that it began to work.
K-Mo
