Re: Bleeding hydraulics on an IH 350
Posted by Armand Tatro on March 12, 2007 at 20:32:22 from (67.176.252.97):
In Reply to: Bleeding hydraulics on an IH 350 posted by Jrry on March 12, 2007 at 09:28:09:
The possible exists that at least one the triangle posts that the bottom of the lift cylinders and the boom attatches to are a
hyd. tank to supply crankshaft-driven pump that is behind the guard at the front of the tractor.Look for breathers; pipe fittings; ect. around that frame. A few loaders did use loader frame for hyd. tank but I might be wrong about this one. Something to check. Armand
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
