Re: 460 Utility questions
Posted by Hugh MacKay on March 13, 2007 at 03:47:28 from (216.208.58.163):
In Reply to: 460 Utility questions posted by Gary in Mozarks on March 12, 2007 at 17:17:57:
Gary: In the case of a 460 filter, fill to level, capacity, etc. will be same for both Farmall and Utility. Fill to level plug should be near clutch pedal.
Those filters make it quite sensitive with water and dirt contaminated oil. Up until 40-60 sreies IH always used a screen for hydraulic oil, these have a paper filter. They are also quite sensitive to low oil. Once you get those two corrected, you will notice quite a difference.
