Re: Super A Hydraulic Pump Drive Gear.
Posted by scotty on March 13, 2007 at 11:44:59 from (199.231.49.128):
In Reply to: Super A Hydraulic Pump Drive Gear. posted by marvin on March 13, 2007 at 11:27:36:
Marvin,
As Gene says the washer gets bent against the nut after you have tightend the nut. The washer should have a tab that fits in the key slot. Once the nut is tightened you bend one side of the washer onto the flat side on the nut. That way it shouldnt loosen up.
scotty
