Re: F-20 Engine Assy with Pictures!!
Posted by FarmallBob on March 13, 2007 at 12:43:31 from (24.31.153.248):
In Reply to: F-20 Engine Assy with Pictures!! posted by SproutW on March 13, 2007 at 07:09:33:
Hi,
I was wondering this same thing. When I did my engine over my pistons were below the block. I would be afraid that much out of the block would be hitting the head or the plugs. You must have .200-.300 thosandths over the block and it seems to me you want the compression to be down inside the sleeve area. Otherwise all that compression is on the headgasket. I hope someone else adds to this that is a little more knowledgeable than myself.
Bob
