Re: H Flywheel/Starter
Posted by Janicholson on March 13, 2007 at 15:26:00 from (66.173.50.112):
In Reply to: H Flywheel/Starter posted by IndianaRed on March 13, 2007 at 13:11:49:
If it were mine, I would look at the drive pinion gear teeth and then bevel the opposite (non-drive) side of the teeth on the ring gear. A dremel and 20 minutes to knock off the edge would just make it less tough on the pinion as it entered. JimN
