Re: H Flywheel/Starter
Posted by gene bender on March 13, 2007 at 15:42:12 from (67.55.226.214):
In Reply to: H Flywheel/Starter posted by IndianaRed on March 13, 2007 at 13:11:49:
I have replaced several and they work just fine. If some teeth are missing you can just take off the ring gear and reverse it that works also. Just use heat to expand the ring gear and it goes on easy.
