Re: I need an H sanity check...
Posted by Janicholson on March 13, 2007 at 16:05:53 from (66.173.50.112):
In Reply to: I need an H sanity check... posted by Mike CA on March 13, 2007 at 11:22:05:
Mike I agree with your assessmant 100%. Do this. Make sure the nonrunner has good oil in it, and that the oil pressure gauge works. Do not try to make it run, that increases the value 500$. With the fuel shut off, and a fresh battery, do a compression check. If it is good, 110-125 would be good for an H (I'd settle for 100), then with the fuel off, and the plugs out, pull it for 200' down the road in 4th gear at about 5mph (nnnooo faster). That will spin the engine well into its normal high idle range and show the oilpressure at cold temps. They usually are near pegged at the high end, 60 PSI or more. It also puts a load on the clutch and gives you an opportunity to put it into the other forward gears and tow it a bit to make sure they are at least not broken (becareful not to pull it faster than a crawl in 1, or a walk in two, or a fast mosey in 3, or 5mph in 4, or 15 in high. Do not do high unless the brakes work well. Then I would buy it. If bad or uneven comression (more than 10% difference between cylinders) or low/no oil pressure, I would offer 500 for the rig just to get the tires and wheels, then trade engines, or parts as needed to get into the parts you need. Good opportunity to do real tradin and swoppin and tractor type goofing off. JimN
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
