Re: 560 d wireing problem
Posted by El Toro on March 13, 2007 at 16:07:02 from (152.163.100.199):
In Reply to: 560 d wireing problem posted by tize on March 13, 2007 at 12:41:02:
You need to check the battery electrolyte in each battery cell. Your batteries should have specific gravity reading around 1.250 and each cell should be close to one another. Buy or make new 00 battery cables. Make sure all spades are soldered as stated earlier and buff
the spades with a wire buffing wheel until shiny. Clean the battery terminals and the ends of your battery cables that are attached to the batteries. Do the same where the batteries are grounded and at the starter solenoid. Rust and paint are good insulators. Hal
