Re: 1949 cub hydraulics
Posted by banjo on March 13, 2007 at 22:40:07 from (65.67.203.124):
In Reply to: 1949 cub hydraulics posted by Spy's Gail on March 13, 2007 at 08:16:30:
I wound up making a tool to fit. I had a peice of flat steel just about the right size and ground the tip to fit the slot and ground the middle to miss the ball and used a cresent wrench to turn it. it was really tight so it took some pressure to break it loose.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
